saitcopuroglu
Script for collapsing each head title
Does someone know what is the script command for collapsing uncollapsing the head title?
This is the default:
I would like to feel free if i would like this result as final (sometimes too much outputs to scroll through)
Thanks all in advance
pmroz
Re: Script for collapsing each head title
Here's an example that will do what you want.  You need to convert the tabulation to a report and then you can send messages to the first outline box, which will collapse the head title.
dt = open("$sample_data\Car Physical Data.jmp");
dtab = dt << Tabulate(
     Show Control Panel( 0 ),
     Add Table(
           Column Table( Analysis Columns( :Weight ), Statistics( Mean ) ),
           Column Table( Analysis Columns( :Turning Circle ), Statistics( Mean ) ),
           Column Table( Analysis Columns( :Displacement ), Statistics( Mean ) ),
           Column Table( Analysis Columns( :Horsepower ), Statistics( Mean ) ),
           Column Table( Analysis Columns( :Gas Tank Size ), Statistics( Mean ) ),
           Row Table( Grouping Columns( :Country, :Type ) )
dt_report = report(dtab);
dt_report[outline box(1)] << close(1);
