WebDesignesCrow
Script for add-in to allow user pick file in a directory
Hello JMP expert,
 I want to build an add-in that can ask user to put file of interest (i.e import .xlsx file into .jmp) then only the rest of script will run.
I have many files in the main folder.
How do i change below script to be able the user pick the directory in "C:\User\Data" folder at the first place?
I've tried to use pick file & pick directory within the () but not working. may be I messed-up something
Thanks.
This is JMP 17
//Open  Table
dt1= Open(
	"C:\User\Data\PlatingToneDatasheet.xlsx",
	Worksheets( {"Merge1"} ),
	Use for all sheets( 1 ),
	Concatenate Worksheets( 1 ),
	Create Concatenation Column( 0 ),
	Worksheet Settings(
		1,
		Has Column Headers( 1 ),
		Number of Rows in Headers( 1 ),
		Headers Start on Row( 1 ),
		Data Starts on Row( 2 ),
		Data Starts on Column( 1 ),
		Data Ends on Row( 0 ),
		Data Ends on Column( 0 ),
		Replicated Spanned Rows( 1 ),
		Replicated Spanned Headers( 0 ),
		Suppress Hidden Rows( 1 ),
		Suppress Hidden Columns( 1 ),
		Suppress Empty Columns( 1 ),
		Treat as Hierarchy( 0 ),
		Multiple Series Stack( 0 ),
		Import Cell Colors( 0 ),
		Limit Column Detect( 0 ),
		Column Separator String( "-" )
Re: Script for add-in to allow user pick file in a directory
The
Pick File()
needs to be executed prior to the Open().
Below is an example of how to get what you  specified
//Open  Table
file = Pick File(
	"Select the Excel file to input",
	"$DOCUMENTS",
	{"Excel Files|xlsx;xlsm;xls", "All Files|*"},
	1,
	0
If( file != "",
	dt1 = Open(
		file,
		Worksheet Settings(
			1,
The Pick File() function is well documented along with an example in the Scripting Index.
The
Pick File()
//Open  Table
file = Pick File(
	"$DOCUMENTS",
	1,
	0
If( file != "",
	dt1 = Open(
		file,
		Worksheet Settings(
			1,
