ih
ih
Script editor: blink a light cursor on dark background
Can the color of the blinking cursor in the script editor be changed to a light color?
I would like to display the script editor using a light on dark background which is possible by 'Customizing Styles' under File > Preferences > Script Editor.  Is it possible to make the cursor blink a color other than black so it is visible on a dark background?
Rob128
Re: Script editor: blink a light cursor on dark background
Hi ih you're right, we need it !
Any update about it ? (I have JMP 13)
Otherwise with a background RGB : 65 ; 65 ; 65 you can see the black cursor...
Regards
ih
ih
As far as I know it still is not possible to change the curser color.  Unless anyone chimes in with a trick to do this I will add it to the JMP Wish List.
cnattrass
You can change cursor color in windows and it will be applied in JMP JSL. I like using the dark theme too, and this fixed it for me
https://www.digitalcitizen.life/how-change-mouse-pointer-size-and-color-windows-10
Here is the link for a how-to
