BookmarkSubscribeRSS Feed
kinsmen
Community Member
Scoring outside the box using JMP 13 pro macosx
I am developing several models in JMP pro and would like to use these outside JMP. I can generate python or C code from the formula depo, but i have been unable to locate the 'Scoring" folder that contains header files. I am running JMP pro 13 on a macbook pro. Any hits where to look?
Thanks
ian_jmp
Re: Scoring outside the box using JMP 13 pro macosx
For my install the 'scoring' folder is in: /Library/Application Support/JMP/13/
And on Windows, you can find the Scoring directory by evaluating:
Get Path Variable("$JMP_HOME/Scoring");
In my system it points to:
"/c:/program files/SAS/JMPPRO/14/Scoring"
Even better: this works on both systems:
Get Path Variable("$ALL_HOME/Scoring");
