rahulsmils
Saving picture crops images
Dear all,
I am new to JMP.  Whenever I try saving images whether I do it manually or through JSL, the saved images are oversized and clipped from the right.
picture << Save Picture(savepath|| outfile ||".png", PNG);
A similar post on jmp community mentioned a simple restart will fix this problem.
However, reboot does not work for me. I have noticed that if I don't connect my second screen [monitor]  to my laptop,  then the saved pictures are correct .
Both monitor [2nd screen] and laptop have same resolution [1080p]
Is there a way I can control this behavior so I don't need to disconnect the second screen every time I want to save images ?
Re: Saving picture crops images
This sounds like a bug that the JMP folks need to resolve. Please submit this to
support@jmp.com
djhanson
Level V
For what it's worth, this JSL clipped image issue just happened to me today. (Win10, JMP 12.2)
Issue: PNG chart images, saved from Bivariate charts, would clip off to the right and bottom maybe by 25% of the image size.
My PC had been in sleep mode before this issue surfaced, then after the PC reawakened and ran the JSL scripts this issue oddly occurred.  So I did a PC reboot and issue resolved and I now get proper sized PNG images of the charts.
mann
I have this problem every day. The images (graphs) in a JMP report are cropped when I save the report to an HTML (where the images become JPGs). If I unplug the external monitor before the save, it saves properly. Please solve this problem.
