Nalla
Saving files to created folder
Hi!
Would like to save a table to a folder created with jsl (Line #7). I have created a variable for it so that I can use it when indicating the directory I want to save my table(Line #27). However, after running the script, the variable("output") does not return the dir path but just the value "1". Thus, I could not save to my intended directory.
Am I missing someting here? Would appreciate any help.
Nalla
Re: Saving files to created folder
Thanks much, Jim! Have added a slash to your suggestion and it worked. Appreciate the help.
OUTPUT = (dirpath||substitute(MDYHMs(Today()), "/", "-", ":", ".")||"/");
Your variable "output" returns the success or failure of the "Create Directory" function, 1 or 0.  If you want it to have the directory path as it value, use the following after creating the directory:
OUTPUT = dirpath""substitute(MDYHMS(Today()), "/", "-", ":", "."));
Nalla
oops, my typo....sorry
