Saving control chart limits in JMP 9
I have a small problem getting the following script, which runs correctly in JMP 8, also to run in JMP 9. It's supposed to add the limits of the control chart to the "Strength" column of data table DT1, as indicated by the asterisk which appears alongside the "Strength" label on the left of the table window to show that the limits calculated from the control chart have been added to the column. (To see the limits that have actually been set, right-click on the header of the "Strength" column of DT1 after running the script, and select "Column Info".)
No such limits are added when the same script is run in JMP 9. Has the syntax changed? I've tried the "set property" and "get property("control limits")" examples in the JMP 9 manual, but either I'm not copying the examples correctly or I'm looking in the wrong place. Many thanks for any help.
style="font-size: 9pt; font-family: "Courier New"; color: black;">
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">Strengths
style="font-size: 9pt; font-family: "Courier New"; color: navy;">=
style="font-size: 9pt; font-family: "Courier New"; color: teal;">1
style="font-size: 9pt; font-family: "Courier New"; color: navy;">,
style="font-size: 9pt; font-family: "Courier New"; color: teal;">2
style="font-size: 9pt; font-family: "Courier New"; color: teal;">4
style="font-size: 9pt; font-family: "Courier New"; color: teal;">3
style="font-size: 9pt; font-family: "Courier New"; color: teal;">5
style="font-size: 9pt; font-family: "Courier New"; color: teal;">6
style="font-size: 9pt; font-family: "Courier New"; color: black;">]
style="font-size: 9pt; font-family: "Courier New"; color: navy;">;
style="font-size: 9pt; font-family: "Courier New"; color: black;">dt1
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">new
table
style="font-size: 9pt; font-family: "Courier New"; color: black;">(
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"DT1"
style="">
column
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Time"
numeric
values(
style="font-size: 9pt; font-family: "Courier New"; color: rgb(0, 0, 221);">index
style="font-size: 9pt; font-family: "Courier New"; color: teal;">20
style="font-size: 9pt; font-family: "Courier New"; color: black;">)))
style="">
column
style="font-size: 9pt; font-family: "Courier New"; color: purple;">"Strength"
numeric
values(Strengths))
style="">
style="font-size: 9pt; font-family: "Courier New"; color: black;">CC1
Control Chart(
style="">
Sample
Label(
style="font-size: 9pt; font-family: "Courier New"; color: navy;">:
style="font-size: 9pt; font-family: "Courier New"; color: black;">name(
style="">
Group
Size(
style="">
KSigma(
style="">
Chart
Col(
Individual Measurement
Moving Range )
style="">
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: black;">CC1
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: navy;"><<
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: rgb(0, 0, 221);">column
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: black;">[
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: purple;">"Strength"
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: black;">]
save limits)
style="font-size: 9pt; line-height: 115%; font-family: "Courier New"; color: navy;">;
style="">
ms
Super User ms
Re: Saving control chart limits in JMP 9
Too simple to guess.
Perfect. Many thanks.
