BookmarkSubscribe
michael_a_mille
Community Trekker
Saving an analysis to powerpoint fails everytime
I ran a capability analysis of about 200 variables and 25 data points. i tried saving as a powerpoint  but it fails everytime. i get the following message:
"JMP Application has stopped working.
A problem caused the program to Stop working correctly. Windows will
dose the program and notify you if a solution is available"
Help!
Re: Saving an analysis to powerpoint fails everytime
Hey Michael,
What version of JMP are you using and is it 32 bit or 64 bit?  Almost sounds like you have a RAM issue.
michael_a_mille
Community Trekker
This Document Contains No Technical Data Subject to the EAR or ITAR. PW PROPRIETARY
________________________________
Version12.2.0 (64-bit)
Hi Michael,
Please send your issue to JMP Tech Support (support@jmp.com) so that they can get the details and try to recreate the problem.
Thanks,
Brian Corcoran
JMP Development
