BookmarkSubscribeRSS Feed
Saving Row Statings When Joining Tables
mrossi
Nov 25, 2013
Is it possible to save the row states when joining a table to another?  For example, if I have some data excluded or marked as a different color and then join that table I lose those row states and need to repeat those actions.  This is something we do frequently and it would be a big time saver if those row states would carry over.
Thanks,
Michael
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
As you've discovered active row states are not carried through a join operation as there's a potential conflict if matching rows in the two data tables both had row states assigned.
Instead you can store your row states in a row state column that will be available in the joined data table.
Here's a video that explains row state columns.
-Jeff
-Jeff
Jeff_Perkinson
Community Manager
Jun 23, 2011
Solution
-Jeff
-Jeff
mrossi
Nov 25, 2013
Thank you, Jeff that helps alot.  I was able to view the video in the response sent to my email, however it's not showing up in the forum thread.  I can see that video being useful for other people in the future.
Thanks again,
Mike
