tmj
tmj
Saving New Script to data table from expression
Hello...I want to be able to create several Variability Charts in a window from a list that contains column names. I can get this to run successfully in real time (thanks to help from other JMP forum posts). But I also want to save script to the data table so that next time the data table is opened the user can just click on the "green triangle" to generate the same window of plots. I'm coming close, it is saving something to the data table, but will not generate the window with plots on click of the green triangle. If I right click and select Edit on the green triangle I can see that the reason it will not produce the window with plots is because the entire script is in quotes. I can't figure out how to remove the quotes. Any ideas?
1st I build string (plotAllStandardExpr) to build the new window through a series of concatenations within a for loop.
2nd the line Eval(Parse(plotAllStandardExpr)) will successfully create the window with all the plots in it.
But the Eval(Substitute(....) line is just saving the quoted string to the data table. I tried Eval(Parse(plotAllStandardExpr)) within the Substitute function but that did not work.
Current Data Table(dtSplit_copy);
plotAllStandardExpr = "New Window(\!"Var Charts: All\!", V List Box(";
for(i = 1, i <= NItems(plotcols), i++,
	plotAllStandardExpr = plotAllStandardExpr || "Variability Chart(
				Y(" || plotcolsString[i] || "),
				X( :Split, :Voltage, :tst_temp ),
				Std Dev Chart( 0 ),
				Points Jittered( 1 ),
				Show Box Plots( 1 ));"
plotAllStandardExpr = plotAllStandardExpr ||"))";
Eval(Parse(plotAllStandardExpr));
Eval(Substitute(Expr(dtSplit_copy << New Script("All Var charts", xxxx)),
	Expr(xxxx), Eval(plotAllStandardExpr)));
Re: Saving New Script to data table from expression
You need to use Parse() to remove the quotes (no need for Eval() as you want the expression). Below are few options
dt = New Table("");
plotcolsString = {"height", "weight"};
For(i = 1, i <= N Items(plotcolsString), i++,
				Std Dev Chart( 0 ),
plotAllStandardExpr = plotAllStandardExpr || "))";
Parse(plotAllStandardExpr);
Eval(EvalExpr(dt << New Script("all var charts", Expr(Parse(plotAllStandardExpr)))));
Eval(Substitute(
	Expr(dt << New Script("All Var charts2", _script_)),
	Expr(_script_), Parse(plotAllStandardExpr))
dt = New Table("");
				Std Dev Chart( 0 ),
Eval(Substitute(
tmj
tmj
Thanks very much. Both options worked as advertised!
