BookmarkSubscribeRSS Feed
celestine
Saving Graphs in JMP Report
Hi everyone,
                 I have a short question. I am trying to save the actual plot by prediction and also prediction profiler graphs and have been able to do so by refering to for instance picturebox(1)<<save ("DIR");
But this method is not a robust one whereby if there are other diagrams which will assume the name of picture box(1) in the JMP fit model (least square fitting), then the wrong graph would be saved particularly for the profiler graphs. Is there any robust way which i can directly refer to the entire section and save them without the need to refer to which picturebox, eg: prediction profiler<<save("DIR")? Thanks.
