BookmarkSubscribeRSS Feed
edayvie
Not applicable
May 25, 2013
Saving Data Tables as Graphics
I'm using JSL to open a saved XLS file and generate a report.  The report contains both charts and small subsets of the original data table, and I wnat to output jpg or png files as well as a journal to save as HTML.  I can ouput the charts with the following script, but it doesn't work on the tables?
Hdrive = "H:\X\Output";
CreateDirectory(Hdrive);
Set Current Directory(HDrive);
Chart1 << save picture("Chart1.JPG", JPEG);
With:   // SubsetofData << journal; //    I am able to get the data table into the journal, but it is does not have the gradient Column Properties I added.  Is it possible to use these in the journal window?
Thanks
Erik
