dilipkumar
Saving Dashboard to .jpg or Png format
Hi
I want to save jmp dashboard into to a image file (.jpg..png). can any one can help in that.
Re: Saving Dashboard to .jpg or Png format
Custom window containing multiple platforms:
path = Pick Directory();
nw = New Window( "Dashboard",
	dt << Distribution( Y( :weight, :height ) ),
	dt << Bivariate( Y( :weight ), X( :height ) )
Wait( 0 );
nw << Save Picture( path || "example.png", "png" );
Custom dashboard:
dash = JMP App(
	Set Name( "Dashboard" ),
	Set Description( "Description" ),
	Auto Launch( 1 ),
	Snap To Grid( 1 ),
	Show Grid( 1 ),
	Show Properties( 0 ),
	Show Sources( 1 ),
	Group By Category( 0 ),
	Dashboard Mode( 1 ),
	Parameters,
	Tables(
		DataTable1 = GuiTable(
			Set Path( "$SAMPLE_DATA/Big Class.jmp" ),
			Set Label( "Big Class.jmp" ),
			Set Location( "Current Data Table" ),
			Set Invisible( 0 )
	Script(JSL Quote(// This script is executed when the application is run.
// Named objects have been created for the application modules
// (for example, "Module1") and the pre-defined object
// "thisApplication" refers to the application object itself.
// Variables and functions declared here are scoped to the
// Application namespace.
	Allocate(
		Module1 = Plan(
			PreAllocate,
			Script(JSL Quote(// This script is executed when a new module instance is
// created.  The pre-defined object "thisModuleInstance" refers
// to the instance object, but other objects such as boxes and
// scripts have not yet been created.  Variables declared here are
// scoped to the ModuleInstance namespace.
// This special function will receive parameters passed to CreateInstance()
OnModuleLoad({},
thisModuleInstance << Create Objects;
// After this point your module instance objects have been created
// and can be referred to by name (for example, "Button1").
Try(TabPage3 << Set Scriptable Object(thisApplication));
			Allocate(
				TabPage3 = Tab Page Box();
				Splitter1 = H Splitter Box();
				TabPage2 = Tab Page Box();
				Scroll2 = Scroll Box();
				Report2 = Platform(
					DataTable1,
					Distribution(
						Continuous Distribution( Column( :weight ) ),
						Continuous Distribution( Column( :height ) )
				TabPage1 = Tab Page Box();
				Scroll1 = Scroll Box();
				Report1 = Platform(
					DataTable1,
			Organize(
				Reparent( Scroll1( Report1 ) );
				Reparent( TabPage1( Scroll1 ) );
				Reparent( Splitter1( TabPage1 ) );
				Reparent( Scroll2( Report2 ) );
				Reparent( TabPage2( Scroll2 ) );
				Reparent( Splitter1( TabPage2 ) );
				Reparent( TabPage3( Splitter1 ) );
				Relocate( TabPage3( 0, 0 ) );
			Initialize(
				TabPage3 << Background Color( 2147483647 ),
				TabPage3 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage3 << Enabled( 1 ),
				TabPage3 << Horizontal Alignment( "Default" ),
				TabPage3 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage3 << Padding(
				TabPage3 << Text Color( 2147483647 ),
				TabPage3 << Vertical Alignment( "Default" ),
				TabPage3 << Visibility( "Visible" ),
				TabPage3 << Title( "Dashboard" ),
				TabPage3 << Tip( "" ),
				TabPage3 << Icon( "" ),
				TabPage3 << Closeable( 0 ),
				TabPage3 << Moveable( 0 ),
				Splitter1 << Background Color( 2147483647 ),
				Splitter1 << Border(
				Splitter1 << Enabled( 1 ),
				Splitter1 << Horizontal Alignment( "Default" ),
				Splitter1 << Margin(
				Splitter1 << Padding(
				Splitter1 << Text Color( 2147483647 ),
				Splitter1 << Vertical Alignment( "Default" ),
				Splitter1 << Visibility( "Visible" ),
				Splitter1 << Dockable( 1 ),
				Splitter1 << Set Width( 1021 ),
				Splitter1 << Set Height( 666 ),
				Splitter1 << Set Sizes( {0.555009823182711, 0.444990176817289} ),
				Splitter1 << set horizontal( 1 ),
				Splitter1 << Set Min Size( 147, 62 ),
				Splitter1 << Set Max Size( 60003, 30000 ),
				Splitter1 << Set Auto Stretching( 1, 1 ),
				TabPage2 << Background Color( 2147483647 ),
				TabPage2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage2 << Enabled( 1 ),
				TabPage2 << Horizontal Alignment( "Default" ),
				TabPage2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage2 << Padding(
				TabPage2 << Text Color( 2147483647 ),
				TabPage2 << Vertical Alignment( "Default" ),
				TabPage2 << Visibility( "Visible" ),
				TabPage2 << Title( "Distributions" ),
				TabPage2 << Tip( "" ),
				TabPage2 << Icon( "Distrib" ),
				TabPage2 << Closeable( 1 ),
				TabPage2 << Moveable( 1 ),
				Scroll2 << Background Color( 2147483647 ),
				Scroll2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Enabled( 1 ),
				Scroll2 << Horizontal Alignment( "Default" ),
				Scroll2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll2 << Text Color( 2147483647 ),
				Scroll2 << User Resizable( {1, 1} ),
				Scroll2 << Vertical Alignment( "Default" ),
				Scroll2 << Visibility( "Visible" ),
				Scroll2 << Width( 565 ),
				Scroll2 << Height( 640 ),
				Scroll2 << Set Auto Scrollable( 1 ),
				Scroll2 << Set Scrollers( 1, 1 ),
				Scroll2 << Set Background Color( 2147483647 ),
				Scroll2 << Set Show Empty( 0 ),
				Scroll2 << Set Clip Printing( 0 ),
				Scroll2 << Set Min Size( 72, 36 ),
				Scroll2 << Set Max Size( 30000, 30000 ),
				Scroll2 << Set Auto Stretching( 1, 1 ),
				Report2 << Background Color( 2147483647 ),
				Report2 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Enabled( 1 ),
				Report2 << Horizontal Alignment( "Default" ),
				Report2 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report2 << Text Color( 2147483647 ),
				Report2 << Vertical Alignment( "Default" ),
				Report2 << Visibility( "Visible" ),
				Report2 << set horizontal( 0 ),
				TabPage1 << Background Color( 2147483647 ),
				TabPage1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage1 << Enabled( 1 ),
				TabPage1 << Horizontal Alignment( "Default" ),
				TabPage1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				TabPage1 << Padding(
				TabPage1 << Text Color( 2147483647 ),
				TabPage1 << Vertical Alignment( "Default" ),
				TabPage1 << Visibility( "Visible" ),
				TabPage1 << Title( "Bivariate Fit of weight By height" ),
				TabPage1 << Tip( "" ),
				TabPage1 << Icon( "Bivariate" ),
				TabPage1 << Closeable( 1 ),
				TabPage1 << Moveable( 1 ),
				Scroll1 << Background Color( 2147483647 ),
				Scroll1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Enabled( 1 ),
				Scroll1 << Horizontal Alignment( "Default" ),
				Scroll1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Scroll1 << Text Color( 2147483647 ),
				Scroll1 << User Resizable( {1, 1} ),
				Scroll1 << Vertical Alignment( "Default" ),
				Scroll1 << Visibility( "Visible" ),
				Scroll1 << Width( 453 ),
				Scroll1 << Height( 640 ),
				Scroll1 << Set Auto Scrollable( 1 ),
				Scroll1 << Set Scrollers( 1, 1 ),
				Scroll1 << Set Background Color( 2147483647 ),
				Scroll1 << Set Show Empty( 0 ),
				Scroll1 << Set Clip Printing( 0 ),
				Scroll1 << Set Min Size( 72, 36 ),
				Scroll1 << Set Max Size( 30000, 30000 ),
				Scroll1 << Set Auto Stretching( 1, 1 ),
				Report1 << Background Color( 2147483647 ),
				Report1 << Border( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Enabled( 1 ),
				Report1 << Horizontal Alignment( "Default" ),
				Report1 << Margin( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Padding( {Left( 0 ), Top( 0 ), Right( 0 ), Bottom( 0 )} ),
				Report1 << Text Color( 2147483647 ),
				Report1 << Vertical Alignment( "Default" ),
				Report1 << Visibility( "Visible" ),
				Report1 << set horizontal( 0 )
	Initialize(
		Module1 << Auto Launch( 1 );
		Module1 << Set Module Type( "Report" );
		Module1 << Set Window Title( "^TABLENAME - ^APPNAME" );
		Module1 << Set Min Size( 0, 0 );
		Module1 << Set Max Size( 30000, 30000 );
		Module1 << Set Auto Stretching( ., . );
) << Run;
Wait( 0 );
dash rep = dash << Get Windows;
dash rep << Save Picture( path || "example.png", "png" );
6 REPLIES 6
Select Help > Scripting Index. Change browser to Display Boxes. Search for 'jpeg'.
//This message applies to all display box objects
Open( "$SAMPLE_DATA/Big Class.jmp" );
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
rbiv << Save Picture( "path/to/example.png", "png" );
dilipkumar
I think this technique works well with single chart, but i want to convert dash board into image and trying to save them.
Please guide
Regards,
Dilip
Wait( 0 );
Custom dashboard:
dash = JMP App(
	Auto Launch( 1 ),
	Snap To Grid( 1 ),
	Show Grid( 1 ),
	Show Sources( 1 ),
	Parameters,
	Tables(
			Set Invisible( 0 )
	Allocate(
		Module1 = Plan(
			PreAllocate,
OnModuleLoad({},
			Allocate(
				Report2 = Platform(
					DataTable1,
					Distribution(
				Report1 = Platform(
					DataTable1,
			Organize(
			Initialize(
	Initialize(
) << Run;
Wait( 0 );
dilipkumar
Thanks for reply, Now i can able to save the image of Dash board, at same time i am trying to hide the dash board , which is appearing now after executing the script. Is there any way to hide the dash board and only image get saved.
Regards,
Dilip
You would add the Invisible argument to the JMP App( ) function call.
You would also have to close the app as well after the picture is saved.
dilipkumar
If possible can you provide any example ?
