BookmarkSubscribeRSS Feed
jason_paquette
SavePicture() PNG dimension change between JSL run manually and with Task Scheduler
I have noticed an odd observation when running my JSL script by two different means.
If I run my JSL script manually, the GraphBuilder report images appear with the correct undistorted dimensions.
Now if I run my JSL script via Task Scheduler, the image dimensions are much smaller and it is very distorted.
I had set the DPI for PNG/JPEG in JMP preferences to be 300, but it doesn't seem to change the outcome.
Does anyone know what might be happening here and why there would be a difference b/w manually running the script and through Task Scheduler?
Thanks,
Jason
Craige_Hales
Staff (Retired)
Re: SavePicture() PNG dimension change between JSL run manually and with Task Scheduler
does task scheduler have a display that JMP runs on, or is it running when your display is locked?  logged out?  I'm not familiar with the windows task scheduler.
have you tried a wait(0); before the <<savePicture(...)?
My quick test says it works if I start the script by double-click and quickly lock the screen.
Craige
