Viz
Viz
Community Member
Save the "Beyond limits" flags from chart to data table
I have a Levey jennings mean control chart. I want to know the count of data points beyond control limits and the count of points failing Tests (Test 5, test 2 etc). It is very tough to manually count the points in the chart. How to export this data to table so that it becomes easy to count the points failing the limits and test?
It would be easier if i have some function similar to 'save summary' fuction in control chart builder.
TIA
Re: Save the "Beyond limits" flags from chart to data table
Which version of JMP are you using? In JMP 15, selecting a specific control chart in the Quality and Process menu creates the chart in Control Chart Builder, and from there you can use the "Save Summaries" function.
