BookmarkSubscribeRSS Feed
gutloja
Jul 31, 2015
Save parameters from fitted line [not predicted values]
Hello, All
Is there a way to save the parameters of a fitted line, not just the predicted values?
I am running the following script, but I do not know if one can save the parameters only, not the predicted values. I want to be able to use the parameters in a different formula, but when I save predicteds, JMP uses an IF statement to predict only the values from my "where" line. I want to fit the line using the "where" line, but predict for all values.
Fit group (
Model1=Bivariate(
    Y( :Name( "1_HD" ) ),
    X( :Name( "Tree1
    Fit Line( {Line Color( {45, 177, 53} )} ),
    Where( :LGTH == "15" ),
Model2=Bivariate(
    X( :Name( "Tree1" ) ),
    Fit Special( xTran( "Sqrt" ), {Line Color( {45, 177, 53} )} ),
Model1 << (curve[1] << save predicteds);
Model2 << (curve[1] << save predicteds);
Thanks, any help will be appreciated,
-JoseL
