BookmarkSubscribeRSS Feed
eben
Community Member
Jan 4, 2013
Save factor scores to data table from PCA in JMP 9?
I'd like to save factor scores from a rotated varimax factor analysis in JMP 9.
I'm obtaining the factors using Analysis->Multivariate Methods -> Principal Components -> on unscaled > factor analysis using a factoring  method of Principal Components  and Prior Commuality set to Principal Components and a rotation method of varimax.  When I've done this before using JMP 8 there was a way to save the factor scores to the data table. I can't seem to find that option in JMP 9. Has it disappeared? I'm using JMP 9.0.2
Thanks for the help!
