rfeick
Sep 30, 2016
Save Multiple Distributions
I have a script that creates a distribution of Nonconformance Reason by Department Group. There are four department groups that the script needs to consider. The script makes the dispositions just fine, but when I try to save a jpeg of the distributions it only saves the last one. Is there a way to save them all? Ideally, I'd like it as one jpeg, but if it can only be done with four individual files that would be workable too.
Jun 22, 2012
Solution
Re: Save Multiple Distributions
If you want them all to be in the same jpeg, an easy way to do this, is, as you create them, copy them to a journal.  Then for each additional one, copy them to a journal and at the end, save the journal as a jpeg.
1 REPLY
Jun 22, 2012
Solution
