uday_guntupalli
Level VIII
Save Analysis to Table Using Variable (in JSL)
All,
    Trying to figure out how to save an analyses to a data table using a variable . I tried multiple options :
1. Option 1 : Adding Col List to table as a variable
myvar = dt << Get column Names("String");
dt << Set Table Variable("ColNames", myvar);
dt << New Script("Save Analyses Using Variable",
Bivariate(myvar[2],myvar[4],Fit Line)
2. Using the column name from a list
BivAfter = Bivariate(
                           Y( Eval(TempCols[r])), //
                           X( :age ),
                          Automatic Recalc( 1 ),
                           Fit Line( {Line Color( {213, 72, 87} )} )
Option 2 works when you are running the script and saves the analyses to the data table . But if I close the script and try to launch the analyses from the table - it fails .
Can anybody help please ?
Best
Uday
Best
Uday
Re: Save Analysis to Table Using Variable (in JSL)
You need to evaluate your column references before adding a new table script. See example below.
dt = Open( "$SAMPLE_DATA\Big Class.jmp" );
myvar = dt << Get column Names();
Eval(
	Eval Expr(
		dt << New Script(
			dt = current data table();
			biv = dt << Bivariate( Y( Expr( myvar[2] ) ), X( Expr( myvar[4] ) ), Fit Line );
Justin
Eval(
	Eval Expr(
		dt << New Script(
Justin
