SVM
Lamine
Mar 17, 2017
Hi everyone,
I tried with with simple data to work with SVM feature in JMP. However, this feature of SVM never work. Someone can help me. I can share my date to understand where is my problem.
Thanks,
1 REPLY
jiancao
Jul 7, 2014
You donot have to select an option in order to run the kmeans clustering. That is, if none is selected, JMP will proceed with its default settings: scale the distances by an overall std deviation (versus within-cluster std deviations), no adjustment applied to the distances per the sizes of clusters, and fit the clusters automatically (versus manually step through iterations one at a time.).
