BookmarkSubscribeRSS Feed
gutloja
Jul 31, 2015
SAS Proc GLM in JMP
Hello, All
I need to re-run a SAS script in JMP, but I do not know how to add a column as co-variable.
This is the SAS script:
DATA EXPERIMENT;
INPUT trat rep Initial a b c Response;
Cards;
PROC GLM DATA=EXPERIMENT;
    class N P K;
    model Response = a |b|c|Initial/solution;
    LSMEANS a |b|c|/stderr PDIFF ADJUST=TUKEY;
    OUTPUT OUT= COVAR R=RES P=PREDICTED;
PROC UNIVARIATE data = COVAR normal;
    VAR RES;
QQPLOT RES/normal (mu=est sigma=est);
PROC GPLOT EXPERIMENT = COVAR;
Plot RES*PRED=PRED/VREF=0;
    RUN;
    QUIT;
And this is the script I am using in JMP, but the results look different.
Fit Model(
    Y( :Response ),
    Effects( :a, :b, :a * :b, :c, :a * :c, :b * :c, :a * :b * :c ),
    Personality( "Generalized Linear Model" ),
    GLM Distribution( "Normal" ),
    Link Function( "Identity" ),
    Overdispersion Tests and Intervals( 0 ),
    Name( "Firth Bias-adjusted Estimates" )(0),
    Run
Any help will be appreciated.
Thank you,
JoseL
jiancao
Jul 7, 2014
Re: SAS Proc GLM in JMP
What part of results are different? Coefficient estimates? If you can provide specifics and data used, I will take a look at it.
