Anastasia
SAS PROC MIXED and JMP Random Effect Variance Estimation are Different
jiancao
Re: SAS PROC MIXED and JMP Random Effect Variance Estimation are Different
The difference you observed is caused by the Kackar-Harville correction applied by SAS Proc Mixed when the DDFM=KENWARDROGER option is set. JMP doesn’t apply this adjustment to the BLUP standard errors. For details, please see http://www.jmp.com/support/help/13/The_Kackar-Harville_Correction.shtml#1502602
To get the same results, replace DDFM=KENWARDROGER with DDFM=SATTERTHWAITE in your SAS code.
Anastasia
Dear All,
I am trying to compare the results of SAS PROC Mixed and JMP mixed model. I thought the results would be the same, but they are not. I hope JMP can give the same results of SAS PROC MIXED. Could anyone help me with it?
My SAS code as following:
proc mixed data=Data;
class sample;
model result= time / DDFM=KENWARDROGER s cl E3 alphap=0.05 residual outp=mixedout;
random sample /s;
ods output SolutionF=F SolutionR=Ran ;
run;
The results for the fixed effect are
Effect
Estimate
Standard Error
DF
t Value
Pr > |t|
Alpha
Lower
Upper
Intercept
7.2638
0.197
15.4
36.86
<.0001
0.05
6.8449
7.6828
time
-0.4636
0.0615
14
-7.54
<.0001
0.05
-0.5955
-0.3317
The results for the random effect are:
Effect
lot
Estimate
Std Err Pred
DF
t Value
Pr > |t|
sample
1
-0.01193
0.1762
4.95
-0.07
0.9487
sample
2
0.1647
0.1762
4.95
0.93
0.3932
sample
3
-0.2869
0.1762
4.95
-1.63
0.165
sample
4
0.1799
0.1762
4.95
1.02
0.3546
sample
5
-0.04579
0.1762
4.95
-0.26
0.8055
Then, I used JMP's interface to generate the following code:
DATA Data1; INPUT time sample result; Lines;
1 1 7.04755019105043
2 1 5.84207852539687
3 1 6.02392278004353
4 1 5.43660061149986
1 2 7.27729854732895
2 2 6.5688837201289
3 2 5.6460380590458
4 2 5.88401060914374
1 3 6.15741854776455
2 3 5.90111584525169
3 3 5.78059226421567
4 3 4.91383166620419
1 4 6.98283726578696
2 4 6.3260371191925
3 4 6.09507016140813
4 4 6.06037720591234
1 5 6.95244413898138
2 5 6.36002369549625
3 5 5.94090548712508
4 5 4.9001077313589
RUN;
PROC MIXED ASYCOV DATA=Data1 ALPHA=0.05;
CLASS sample;
MODEL result = time/ SOLUTION DDFM=KENWARDROGER;
RANDOM sample / SOLUTION ;
RUN;
I got:
Parameter Estimates
Term
Estimate
Std Error
DFDen
t Ratio
Prob>|t|
Intercept
7.2638308
0.197046
15.45
36.86
<.0001*
time
-0.463589
0.061501
14
-7.54
<.0001*
Random Effect Predictions
Term
BLUP
Std Error
DFDen
t Ratio
Prob>|t|
sample[1]
-0.011928
0.153244
4.948
-0.08
0.9410
sample[2]
0.1647348
0.153244
4.948
1.07
0.3320
sample[3]
-0.28692
0.153244
4.948
-1.87
0.1207
sample[4]
0.1799016
0.153244
4.948
1.17
0.2938
sample[5]
-0.045789
0.153244
4.948
-0.30
0.7772
It seems like Std error estimates for random effects are not the same in JMP and SAS. I am wondering if there is anyone know how could I code the JMP to make it is the same results as SAS.
Thank you very much,
Anastasia
I think that this kind of question is best served by [email protected]. They are very friendly, almost as friendly as the people here!
jiancao
dr_winfried_koc
Thanks for clarification.
I work in environments where both SAS and JMP are in use; therefore I appreciate consistency between both. In case where certain differences are intended by SAS Institute, these should always be indicated in the documentation.
Anastasia
Thank you very much. It works.
