gutloja
Running average by data series using For Loop and same script on multiple columns
I am running a three-point moving average [MA] in data series of fixed length, and collected at fixed time intervals [i.e., series of 150 data points collected every 30 minutes for weeks at the time]. A traditional MA would merge two data series together, so I ended up adding a new column with data series [incrementing numbers using "Sequence( , , ,)"], and using it as a limiter for the range where the MA should run. The script works and it is quite simple, but I want to  use a more effective one.
Is there a way to do this using a For Loop where "i" is the data series ID?
How do I run the same script on multiple columns without having to change the variable name?
This is the script I am currently using:
If( :Time > 1 & :Time < 149,
    Mean(
    :T1_F[Row() - 1, Empty()],
    :T1_F[Row(), Empty()],
    :T1_F[Row() + 1, Empty()],),
Where "T1_F" is my Y variable to smooth, and I have a couple of hundred Y's to smooth.
Any advise would be appreciated.
-JGL
robot
Re: Running average by data series using For Loop and same script on multiple columns
Hi JGL,
One solution is to build a loop using Eval(Parse(Eval Insert())) to insert your desired columns into a formula.  An example script is below.
// Example.
bigClass = Open( "$SAMPLE_DATA/Big Class.jmp" );
colList = List( :height, :weight ); // Columns to create moving averages.
For( i = 1, i <= Length( colList ), i++,
col = Column( colList[i] );
colName = Concat( "MA(", colList[i] << Get Name(), ")" );
      Eval(
            Parse(
                  Eval Insert(
                        "bigClass << New Column( \!"^colName^\!",
            Numeric,
            Continuous,
            Format( \!"Best\!", 12 ),
            Formula( Mean( As Column( ^col^ )[Row() -1, Empty()],
            As Column( ^col^ )[Row(), Empty()],
            As Column( ^col^ )[Row() + 1, Empty()] ) ) );"
robot
Hi JGL,
// Example.
      Eval(
            Parse(
                  Eval Insert(
            Numeric,
            Continuous,
