Below is a script that create the summary output table you stated was what you wanted. The script goes from the JMP data table you provided, through to it's completion. About 80% of the script was actually created by running the steps interactively in JMP, and then just having JMP save the script it used for the interactive processing to a script window. All of the steps and functions used in the script are documented in the Scripting Guide and Scripting Index
Help==>Books==>Scripting Guide
Help==>Scripting Guide
// Correct the data table using the JMP table imported from the Excel file
For( i = 2, i <= N Cols( dt ), i++,
Column( dt, i ) << set name(
Word( 1, Column( dt, i ) << get name, " " ) || " " || Column( dt, i )[1]
dt << delete rows( 1 );
Column( dt, i ) << data type( numeric ) << modeling type( continuous )
// Change the name of the first column to H(Oe)
Column( dt, 1 ) << set name( "H(Oe)" );
// Create a list of all numeric column names
colNamesList = dt << get column names( numeric );
// Summarize the data
dtSum = dt << Summary(
Mean( Eval( colNamesList ) ),
Freq( "None" ),
Weight( "None" ),
statistics column name format( "column" ),
Link to original data table( 0 )
// Create final table and sort it in alphabetical order
// First delete the unneeded column N Rows
dtSum << delete columns( "N Rows" );
dtFinal = dtSum << Transpose(
columns( Eval( colNamesList ) ),
Label column name( "Column" ),
Output Table( "Summary " )
// Change the name of the "Row 1" column to "Mean"
dtFinal:Row 1 << set name( "Mean" );
// Sort the data table
dtFinal = dtFinal << sort( by( Column ), order( Ascending ), Replace Table( 1 ) );
I still can't output in a journal. I am trying this right now, but no luck.
jrn = New Window( "Reports", <<Journal );
jrn << Append( H List Box( (dtFinal << Report) ) ) ;
jrn <<Save Journal(("C:\!Destination!\Output.jrn") ) ;
@tylerram123,
Can you help me understand what you need this journal for ? Try this example. I tested it and this will work.
MyJrn = dt << journal;
The excel sheet I am using and recieving has six tabs and I want to consildate all the data into one journal so I can send it off or do more analysis. Thanks!
