jim_pappas
Running a JSL script within another JSL script
Hello
I hope this one is easy, but I'm having difficulties figuring it out (new JSL user)...
I have a "large" JSL script, of which within it, I want to run a "short" JSL script.   However, I do not want to put the code of the shorter script within the larger one since the same code is used within several of my scripts (its a database query builder).
Is there a way to simply run the shorter script (it's on my drive:  Q:\Tissue Effect Research\JMP\JMP Apps and Scripts - Read Only\Data Puller) from the larger one?
Thanks, Jim
11 REPLIES 11
LogitTurtle576
Re: Running a JSL script within another JSL script
Thanks for the solution
lala
Level IX
Can JSL use "go to"?
Thanks!
