markbarrish
Running SAS in JMP
I have a large database in JMP from which I need to run a GLM with count data as the response variable. There is significant over-dispersion with Poisson regression so I may need to try a negative binomial (or ZI negative binomial) model which cannot be run in JMP. Can I have SAS run the negative binomial model from JMP and then use JMP for analysis and graphing?
ian_jmp
Re: Running SAS in JMP
Absolutely, yes. For JMP SAS integration, please see:
http://www.jmp.com/support/help/Integrating_JMP_and_SAS.shtml
Also, be aware that JMP Pro may itself do what you require. See, for example:
http://www.jmp.com/support/help/Examples_of_Generalized_Linear_Models.shtml
