Running Python Script from JSL
I would like to run Python script from my JSL code. What is the best way to do that? Thank you
11 REPLIES 11
Re: Running Python Script from JSL
Here's an example I was playing with
txt=runprogram(executable("python"),options({"C:\Users\User\Desktop\tweepy\twpy2.py"}),readfunction("text"));
Tweepy is a python package for twitter.  This example expects the python program to start, produce output, and terminate, before the JSL continues.  There are other ways to use RunProgram.
nascif_jmp
Update: Since JMP 14.0 (and much improved in 15.0), the best way to run Python from JSL is now to use the JMP interface implemented in the commands Python Init(), Python Submit(), etc.
More information here:
https://www.jmp.com/support/help/14-2/python-integration-functions.shtml
For a wrapper that supports running Anaconda virtual environments, check:
https://community.jmp.com/t5/JMP-Scripts/Anaconda-Environments-Integration/ta-p/221565
