BookmarkSubscribeRSS Feed
gutloja
Jul 31, 2015
Running ARIMA autoselecting FROM-TO range
I am running an ARIMA model, but I also would like to test the same parameters on different files of various lengths. Is there a way to auto select "To" and "From" range?.
I already tried using:
N Row( :RowNO )
Max( :RowNO )
Global variable = 708
[Where "RowNo" is a column created with "Sequence( , , , )" from 1-N]
But I cannot make it work. I have been able to use successfully "Max( :RowNO )" for variable Y axis in graphs.
This is the code I am currently using.
ARIMA Forecast(
    :Name( "1_OUT_Vs" ),
    708,
    ARIMA( 1, 1, 4 ),
    {AR Coefficients( {0.657554020208914} ),
    MA Coefficients(
        {0.133731342003291, -0.381271305370554, 0.59558889528982, -0.503671255632547
    ), Intercept( -0.00198098398142672 )},
    Row() - 708,
    Row() - 708
Thank you for your help.
-JGL
