geof
Run jsl script from vbs
Hello
I woud like to run a script "run.jsl" from vbs. I tried something like:
Dim objJMP
Dim objJSL
Dim strfileName
strfileName = "D:\JMP\run.jsl"
Set objJMP = CreateObject("JMP.Application")
Set objJSL = objJMP.OpenDocument(strfileName)
objJMP.Visible = True
objJMP.RunCommand("run.jsl")
objJMP.Quit
But doens't work
Any idea?
Thanks
geof
Re: Run jsl script from vbs
Ok I found the solution.
add
//!   first line of the jsl script, so it will run automaticaly when you open the file
then the vbs below works ok
Dim objJMP
Dim objJSL
Dim strfileName
objJMP.Quit
geof
add
Dim objJMP
Dim objJSL
Dim strfileName
objJMP.Quit
