BookmarkSubscribeRSS Feed
ih
Community Trekker
Sep 30, 2016
Run Script on Platform Launch
Can JMP launch a script every time a platform is launched or a report is created from that platform?
For example, how can these two buttons (as described here) be added to this platform every a user launches it from the menu?
Jun 22, 2012
Solution
Re: Run Script on Platform Launch
The way I have accomplished this in the past, has been to change the menu bar by hiding the original menu entry, and replacing it with my new replicate + mondifications code
Several years ago, I did put in a request to be able to add exit code to platforms......but no response has been made
Jun 22, 2012
Solution
