Amrit
Community Trekker
Risk-Based Monitoring and Fraud Detection in Clinical Trials Using JMP® and SAS® difference 12 vs 13
Please could you help me know/provide if there is any documentation available to find the difference between version 12 and 13 in JMP for risk based monitoring in clinical trials.
Thanks in advance,
Kind Regards,
Amrit
Re: Risk-Based Monitoring and Fraud Detection in Clinical Trials Using JMP® and SAS® difference 12 v
Hi Amrit,
I think you may be refering to JMP Clinical instead of JMP. JMP 12 and 13 do not have RBM capabilities, only JMP Clinical. The current version of JMP Clinical is 6.1.2 and the release notes can be found attached for the difference between JMP Clinical 5 and 6.
Also, latest release documentation and user guide can be found here:
https://www.jmp.com/en_us/support/jmp-clinical-software-updates.html
Hope this helps.
Chris Kirchberg
Chris Kirchberg
Principal Systems Engineer, Life Sciences - JMP Global Technical Enablement
SAS Institute, Inc. - Denver, CO
JMP – A Division of SAS Institute | www.jmp.com
Hi Amrit,
Hope this helps.
Chris Kirchberg
Chris Kirchberg
Amrit
Community Trekker
Thanks a lot Chris
