martinschmid
Returning either list of rows or NULL in my function. How do I work with multiple return values in a jsl-script?
I guess my problem can be solved pretty easily.
I want to write a function, that either returns a list of row-numbers or NULL in dependency of an if-clause inside my function.
How can I handle multiple return values and how can I return NULL?
My function should look somehow like this:
myFunction = Function( {...}, {...},
     list = { ... };
     if(...)
          then return list
     else return NULL
I have already found this tutorial:
https://community.jmp.com/message/25472#25472
but what if I have multiple return values, like:
return1=...
return2=...
how do I handle these, and how do I return NULL then?
Thank You for your help!
pmroz
Re: Returning either list of rows or NULL in my function. How do I work with multiple return values in a jsl-script?
Might be safer to return a 0-element list if your if clause doesn't find any row numbers.
    my_list = {};
    if (my_test,
      my_list = {1, 2, 3};    // Test passed, return values
      my_list;
one_list = myFunction(...);
if (nitems(one_list) > 0,
      // handle items in the list
pmroz
    my_list = {};
    if (my_test,
      my_list;
martinschmid
Thank You!
This solved my problem.
