BookmarkSubscribeRSS Feed
Hegedus
Jun 23, 2011
Return the number of items in data row
I have a data set where one of the columns is a list of entries such as  1,2  or 7,8,10,12 or blank  I would like to create a new column with the number of entities in each row.
I have tried
New column(
  "Num_Bumps",
  Numeric,
  Continuous,
  <<set each value(N Items(:Pad #))
Where Pad # is the column with entries.
This doesn't work because Pad # is not recognized as a list.
How should it be coded?
pmroz
Jun 23, 2011
Solution
Re: Return the number of items in data row
You could use the WORDS function with a comma delimiter.
dt = New Table( "Example", Add Rows( 4 ), New Column( "Pad #", Character, Nominal,
        Set Values( {"1,2,3", "4,5,6", "", "1,2"} )
dt << New Column( "Num_Bumps", Numeric, Continuous, Format( "Best", 12 ),
        Formula( N Items( Words( :Pad #, "," ) ) ) );
pmroz
Jun 23, 2011
Solution
Hegedus
Jun 23, 2011
Thank you.
