BookmarkSubscribe
acid1c
Response Surface Plot With Projection
How can I generate a response surface plot with a projection, as seen in the following diagram:
Source: P. Kardar, M. Ebrahimi, S. Bastani, M. Jalili, Progress in Organic Coatings, 64(2009), 74-80
acid1c
Re: Response Surface Plot With Projection
^ Bump to the top
ian_jmp
The Surface Plot can do something similar if you select the correct options. See the documentation, particularly Surface Plot Controls and Settings.
The code below shows an example: Do 'File > New > New Script', cut and paste it, then 'Edit > Run Script'.
NamesDefaultToHere(1);
dt = New Table( "Surface Plot Options",
  Add Rows( 0 ),
  New Column( "x", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) ),
  New Column( "y", Numeric, "Continuous", Format( "Best", 12 ), Set Values( [] ) ),
  New Column( "z",
  Numeric,
  "Continuous",
  Formula( Sin( Sqrt( :x ^ 2 + :y ^ 2 ) ) / Sqrt( :x ^ 2 + :y ^ 2 ) )
dt << Surface Plot(
  Columns( :z ),
  Show Contour( "Below" ),
  Formula( "z" ),
