  • Due to inclement weather, JMP support response times may be slower than usual during the week of January 26.
    To submit a request for support, please send email to support@jmp.com.
    We appreciate your patience at this time.
gianpaolo
Response Screening DataTable
Hello
i'm writing a script that perform Response screening because my Idea is to work with  the output "Pvalues" table of this report, but im not able to assign a "dt"  variable to Pvalues table.... so with script im not able to move from another table to Pvalues.
Someone can help me
obj = selectDT[1] << Response Screening( Y( Response ), X( Eval( Predictor ) ), save Pvalues )
Thanks in advance
Gianpaolo
Gianpaolo Polsinelli
Re: Response Screening DataTable
Use the << Get PValues message to set the pointer to the output data table.
Open( "$Sample_Data/Probe.jmp" );
obj = Response Screening(
	X( :Process ),
	Y( Eval( 8 :: 394 ) ),
	Save Outlier Indicator
dtPValues = obj << Get PValues;
This example was taken in the most part from the example in the Scripting Index
     Help==>Scripting Index
	X( :Process ),
