BookmarkSubscribeRSS Feed
tajrida
Apr 8, 2015
Request: JMP Webinar - outlier analysis - benefits and use
Hi There,
I request a JMP webinar on "outlier analysis" specifically the benefits and use. Please share any useful content (video/article/webcast) link on the same - thanks
Note: highly interested in knowing more about "outlier analysis" in context of "odds ratio" i.e. how a factor having outliers can influence other factors in system/process
gail_massari
Community Manager
Feb 27, 2013
Re: Request: JMP Webinar - outlier analysis - benefits and use
Hi Mohammed,
Thank you for the suggestion.  I looked through our modeling videos and also checked with our Academic Team., We do not have a tutorial on the general benefits and use of outliers. Currently our webcasts cover capabilities related to particular business problems (case studies).
I will suggest to our presenters that when they are describing findings and showing outliers, they might elaborate on why or why not, for the case they are exploring, outliers can be useful to consider or handle in a particular way.
If you have not found this documentation, perhaps you will find it useful.  The last links describes the calculations used for our ODDS RATIO report.
Modeling: Explore Outliers Utilities
http://www.jmp.com/support/help/Explore_Outliers_Utility.shtml
Logistic Fit Platform: Odds Ratio Option
http://www.jmp.com/support/help/Logistic_Regression_with_Nominal_or_Ordinal_Resp.shtml#73971
http://www.jmp.com/support/help/Logistic_Fit_Platform_Options.shtml#98620
tajrida
Apr 8, 2015
Thanks
