lance
Reports listed as child of parent file in Window List
I created several reports, saved them as jrp files, ran each jrp, then saved the script from the Log window as a new script in the original table. The problem is that when I run these scripts, the reports (distribution and run charts) do not show as children of the original table. I will have several reports for several tables open at the same time and it would be far neater if they show correct in the hierarchy in the Window List. Is there a way to do this?
