Ted
Ted
Repeated measures (the third attempt to formulate)
In which platform will it be possible:
1) show two distinct curves (with confidence intervals at points for each curve) and
2) to evaluate (using tests) the difference between these curves (see pic.)
P.S. Patients ID and time are not random value (they are fixed)
GM
GM
Re: Repeated measures (the third attempt to formulate)
@Ted have you looked into the MANOVA personality in the Fit Model platform?
Ted
Ted
@GM, thank you!Yes, the MANOVA platform estimates the difference of the curves (generated by the covariate "divider"). But I don’t see there the possibility of constructing curves (with CI) as in my picture. (P.S. In addition, there are two aspects: 1) repeated measurements and 2) values "ID" and "time" are fixed.)
In general, leaving the details, I would like to hear a hint how to approach the formulated problem
