BookmarkSubscribeRSS Feed
sornasst
Feb 2, 2016
Repeated Measure MANOVA: 95% Confidence Interval on LSM?
Hi, I'm quite new at using the MANOVA Repeated Measure model to analyze biological data.
I would like to know if there is a JMP feature that would allow me to retrieve the 95% Confidence intervals for the calculated Least Square Means produced by the model.
Thank you
jiancao
Jul 7, 2014
Solution
Re: Repeated Measure MANOVA: 95% Confidence Interval on LSM?
MANOVA doesn't report them, but you can get them by fitting separate standard least squares models to each of responses, Then right-click in the LSM report and select Columns > Lower 95% (or Upper 95%) to get them.  See the example in the attached table.
jiancao
Jul 7, 2014
Solution
