BookmarkSubscribe
sharong
Repeat Fit Line for all records in report output?
Is there a way to repeat the Fit Line selection for all records in a Fit Y by X analysis report?
I'm running a Fit Y by X analysis on my data by NAICS sector so my report output has a lot of records (2 dozen or so sectors). If there's a way to apply Fit Line to all, and not by each record, it will save me a lot of time!
Thanks in advance...
ms
Super User ms
Re: Repeat Fit Line for all records in report output?
Most commands in reports can be broadcasted to all similar display boxes. Hold down cmd key (Mac) or ctrl key (Windows) while clicking on the red triangle and select Fit line which then will apply to all by-levels. A very convenient, but not obvious to find, feature of JMP.
ms
Super User ms
sharong
It works! I was using ctrl as described in the JMP user resources, but am on a Mac, so needed to use the cmd key instead.
Thanks, MS - You just saved me a lot of time!
