bjbreitling
Rename Data Table
How would I rename a table or name it period before it is created with a script.  Below is the code for the table:
combinedTbl = Report(fitModelPlt[1])["Effect?"][Table Box(1)] << Make Combined Data Table;
Regards,
stan_koprowski
Re: Rename Data Table
Brandon,
You can use the Set Name command.
Cheers,
Stan
For example,
combinedTbl << Set Name("fit_estimates");
stan_koprowski
Brandon,
Cheers,
Stan
For example,
