aharro
Removing 5th percentile from a dataset
Does anyone have a jsl snippet of code that can remove the 5th percentile from a dataset? I've tried using the table summary.
Might be able to do it with the distribution chart.
Re: Removing 5th percentile from a dataset
You could also use Col Quantile() function
rows_of_interest = dt << Get Rows Where(:height > Col Quantile(:height, 0.8));
wait(1); // for demo purposes
dt << Delete Rows(rows_of_interest);
AlbertoJD2000
@jthi Thank you appreciateblank.png for any solution..
