BookmarkSubscribeSubscribe to RSS Feed
Re: Remove all values in a numbercolbox (JMP 10)?
pmroz
Jun 23, 2011
I'm using JMP 10 to develop some user interfaces.  I have a dialog box with some search criteria in the top section and a tablebox with stringcolboxes and numbercolboxes in the lower section.  The user enters search criteria, pushes a Refresh button, and the data in the tablebox is refreshed.  Occasionally their search yields 0 records.  When this happens the stringcolboxes clear out to no values, but the numbercolboxes don't change.
Specifically, once I add values to a numbercolbox using << set values([1, 2, 3]), I can change the list to a different matrix e.g. << set values([4, 5, 6, 7]).  But if I want to remove all values using << set values([]), it doesn't work.
Here's an example that illustrates the problem:
nw = new window("Test",
    tablebox(
        a = stringcolbox("String Col Box", {"Hello", "World", "Fubar"}),
        b = numbercolbox("Number Col Box", [1, 2, 3])
    button box("2 Values",
        a << set values ({"AAA", "BBB"});
        b << set values([98, 99])
    button box("0 Values",
        a << set values({});
        b << set values([])
Thanks for your help!
Regards,
Peter
danschikore
Sep 21, 2012
Solution
This is indeed a bug in JMP 10 and prior versions.  It is now fixed for JMP 11.
There is an alternate message <<Set({}) which takes a list - this will work with JMP 10.
ms
Jun 23, 2011
That's very strange. I don't see any reason why it should not work. Probably a bug.
This idea may work:
b0 = Expr( Number Col Box( "Number Col Box", [] ) );
nw = New Window( "Test",
  Table Box(
  a = String Col Box( "String Col Box",
  b = Number Col Box( "Number Col Box", [1, 2, 3] )
  Button Box( "2 Values",
  a << set values( {"AAA", "BBB"} );
  b << set values( [98, 99] );
  Button Box( "0 Values",
  b << delete();
  a << set values( {} ) << sib append( b = Eval( b0 ) );
ms
Jun 23, 2011
On second thought, this approach may be better and less error-prone in a more complex context:
  Table Box(
  a = String Col Box( "String Col Box", {"Hello", "World", "Fubar"} ),
  a << set values( {} );
  For( i = N Items( b << get ), i > 0, i--,
  b << delete row( i )
danschikore
Sep 21, 2012
Solution
pmroz
Jun 23, 2011
Thanks guys.  The command << Set({}) works perfectly!
