paulamkueter
Removal of timestamp
I am challenged by the removal of a timestamp in a cell. See example. 5/20/2022 12:00:00 AM
I want to remove the 12:00:00 AM and achieve this  5/20/2022.
Thank you in advance for your assistance.
Re: Removal of timestamp
Go to the Column Info dialog for the column.  From the Format Drop Down Arrow, select
     Date=>m/d/y
That will change the displayed value
If you want to hide the timestamp you can do what Jim suggest. If you want the time removed, you can create new column with formula such as:
:DateTime - Time Of Day(:DateTime)
to remove time
