galactus3000
Reliability Life Distribution confidence interval purple region ... JSL to customize?
I am working with the Life Distribution platform and would like to be able to generate plots with elsewhere-calculated "purple" confidence intervals.  Is there an easy way to leverage JSL hooks to override and supplant confidence intervals in the CDF plot?
I can supply a jpg screenshot of this notion if need be.
Re: Reliability Life Distribution confidence interval purple region ... JSL to customize?
You can turn off the display of the confidence interval with a command in the platform menu so that same action is available with JSL. You can append a script to the frame box to draw the graphics you want.
