anders_bankefor
Relative path, Interactive datafilter and time series analysis
I've got a  3 in 1 question:
1. I would like JMP to pick up a "template-table" from the same directory that the script is located. This pathway may vary depending on user due to network setup. I've managed to use the following "fixed" link:
TempTable = "K:\...\TableTemplate.jmp";
open (TempTable);
(this setup works)
the data table is located in the same directory as the script, therefore I would reason that I should be able to use:
TempTable ="..\[path]\TableTemplate.jmp"
open (TempTable);
However this doesnt work.
2. I would like to create an interactive data filter:
dt = open (table);
TableWindow = New Window( "Enter Input",
      H List Box (
//Create a text box and input box.
          Text Box ("Enter the Values"),
          Spacers Box (size (1,10));
          Filter = Number Edit Box ( . ),
//Create a button box that will use the Filter to select and subset specific data into a new table.
           Button Box ("Add value",
               If ( Is Missing (Filter<<get) == 0 ),
               dt << Select Where( :Value == (Filter <<get) ),
               dt << Subset(( Selected Rows ), Output Table Name("subset"));
               TableWindow << Close Window;
               Filter << set ( . );
               Dialog ("Value incorrect");
3. I've got a script that plots numerical values on the Y-axis and batches (characters) on the X-axis. I'm trying to figure out a way to generate a report that will state all samples with values below the avarage of the whole population. Maybe it could work something like this:
dt << Select Where(:Sample == X),
meanX = Mean(Value);
dt << Select Where (:Sample == X & Value < meanX)
//subtset all columns related to these rows
Thanks for all the help, cheers!
anders_bankefor
Re: Relative path, Interactive datafilter and time series analysis
2nd question is solved by:
InputWindow = New Window( "Enter Input",
V List Box(
  Spacer Box( size( 1, 10 ) ),
  Text Box( " Enter in the inputs" ),
  H List Box(
   Text Box( "Max respons uppgift 1" ),
   Spacer Box( size( 10, 1 ) ),
   Median = Number Edit Box( . ),
  H List Box(
   Button Box( "Lägg till värde",
    If( Is Missing( Median << get ) == 0,
     Table << Select Where( :ISU > (Median << get) );
     Table << Subset(( Selected Rows ), Output Table Name("Ber1"));
     InputWindow << Close Window;
     Median << set( . );
     Dialog( "ogiltiga värden:" );
   Button Box( "Stäng",
David_Burnham
if you still have a problem with any of these then it's probably best to post them as individual questions
-Dave
anders_bankefor
thank you for your reply. I've been able to solve two of these problems however the relative path issue still remains an open issue. I will create a new ticket for this issue.
Kind Regards
Anders
