nikles
Refreshing Windows and Window Persistence
Hi.  I have an expression that first creates a modal notification window, and upon hitting OK, it creates a second, edit window.  In the edit window, there's a Refresh button that closes the window and re-executes the original expression. When I hit "Refresh", the edit window closes as expected, and the modal notification window appears again.  However, the second iteration of the edit window appears with a "2" appended to its name ("editwin 2") even though the original editwin already closed.  Furthermore, the << On Close script that is supposed to immediately run when the edit window is closed the first time does not run until after the second instance of the notification window is closed and the second instance of the edit window is about to open.  It seems like although the edit window is closed, it persists in the memory until the next instance of the edit window appears.
Does anyone have a good explanation for this behavior, and more importantly, what's the workaround?
Thanks.
Delete Symbols();
editwin.expr = Expr(
  BB1 = ButtonBox("ok",
  Window("editwin") << Close Window;
  BB2 = ButtonBox("Refresh",
  editwin.expr;
  modwin = New Window("modwin", << Modal,
  TextBox("I'm a notification window"),
  ButtonBox("OK", Write("Closing modwin\!N"))
  editwin = New Window("editwin",
  TextBox("I'm an edit window"),
  BB1, BB2
  editwin << On Close(Write("Closing editwin\!N"));
  editwin << Set Window Size(300, 200);
editwin.expr;
6 REPLIES 6
Re: Refreshing Windows and Window Persistence
I was not able to solve the window naming issue.  It appears that JMP holds the name in reserve for the duration of the execution of a given EXPR.  However, the code below removes the concern over the window name, by taking all actions on the window's handle, rather than the window's name:
Delete Symbols();
  editwinx << Close Window;
  editwin.expr;
  ButtonBox("OK", Write("Closing modwin\!N"));
  editwinx = New Window("editwin",
  BB1, BB2
  editwinx << On Close(Write("Closing editwinx\!N"));
  editwinx << Set Window Size(300, 200);
editwin.expr;
nikles
Unfortunately your script does not prevent renaming of the window.  I tried and get the exact same behavior.
ms
Super User ms
FYI, I tried the script in JMP 12 for Mac and I did not see this problem; editwin was named editwin every time, no automatic numbering occurred.
However, in JMP 12 for Windows I was able to reproduce the problem: editwin 2, editwin 3 etc. are generated after every refresh. No idea why.
Txnelson approach presents a good workaround
nikles
Interesting.  I'm using JMP 11.1.1 for Windows (64bit).  I'm not prepared to dismiss the problem yet as a 11 vs 12 issue or Mac vs Windows issue though.  At any rate, I still need to find a workaround for my current config.
you are correct, my work around does not cix the window nwaming issue, but it does remove the dependency on the window name. jJMLP Jmp passes window closing off to the operating system and therefore it looses absolute control of when the window actually gets closed
David_Burnham
Just offering this code in case it gives you a different approach to the problem you are trying to solve
Do Edit Window = Function({},{Default Local},
    nwEdit = New Window("editwin", <<Modal,
          ButtonBox("OK" ),
    If (nwEdit["Button"]==-1,
        retVal = 1
        retVal = 0
    retVal
nw = New Window("modwin", <<Modal,
  << On Validate(
      Do Edit Window()
  ButtonBox("OK", Write("Closing modwin\!N");)
-Dave
