BookmarkSubscribe
satish
Referring to Outline Box name dynamically
Hello all, I am writing scripts to generate control charts for each column in a table and moreover change chart titles using a For loop. In order to change the OutlineBox title I need to first know the name of the outlinebox and that's where I am stuck. How can I dynamically change the bolded text below ("XBar of Delay"). I tried OutlineBoxName = "XBar of" || varCustomName where I set the varCustomName but I get an error Outlinebox not found.
Any help much appreciated.
Control Chart(
  Sample Size( :Day ),
  KSigma( 3 ),
  Chart Col( :Delay, XBar, R ),
  Dispatch(
  "XBar of Delay",
  OutlineBox,
  Set Title( "XBar of Delay test" )
satish
Re: Referring to Outline Box name dynamically
Figured this one...
param = "XBar of Delay";
Show( param );
cChart =
Control Chart(
  KSigma( 3 ),
report(cChart)[Outlinebox( param )] << set title( "test" );
satish
Figured this one...
Show( param );
cChart =
Control Chart(
  KSigma( 3 ),
