ENTHU
Referencing to a specific data table
I have a data table dtValues.I have sorted the data table as follows -
dtValues << Sort(
By( :test_end_date_1 ),
Order( Ascending ),
Output Table( "out_sorted" )
Now I want to get unique values from a column "weight" from the out_sorted table.
I tried the following code -
unique_wt = {};
unique_wt = Associative Array( dtValues:weight ) << Get Keys
But this code gives unique values from the table before sorting.I am looking for weight values from the sorted table.
How do I get around this?
Re: Referencing to a specific data table
You need to set a pointer to the new data table that is being created.  The below code does that:
dtSorted = dtValues << Sort(
	Order( Ascending ),
unique_wt = {};
unique_wt = Associative Array( dtSorted:weight ) << Get Keys;
ENTHU
Thanks for the response.
But looks like
outputs the key in ascending order by default.
I wanted to get the weight values in the order they appear in the column and not in ascending order.
Is there any other way to achieve this?
Thanks
The following quote is taken from the Scripting Guide, in reference to Associative Arrays
• Though associative arrays are not usually ordered, in JMP, keys are returned in
   alphanumeric order for the purpose of iteration and serialization.
ENTHU
Is there a work around for this? Like may be get all the values in the column and remove duplicates?
Without using associative arrays that is.
