BookmarkSubscribe
Referencing TableBox columns by their position within the TableBox
This one is related to the recent thread of mine about identifying the type of display box within a Table Box, but it's essentially a different question so I thought I'd better start a new one for it.  If I have a TableBox containing several NumberColBoxes and StringColBoxes in no prespecified order, how can I reference each one purely by its position within the TableBox?
For example, to get at the third column in a TableBox called "MyTableBox" I'm assuming I would need something like MyTableBox[3], MyTableBox << child(3), (MyTableBox << child())[3] or whatever; however I've tried as many constructions like this as I can think of without success.  I can't use MyTableBox[StringColBox(3)] or something like that because I can't be certain that it is the third StringColbox.
The answer to this is almost certainly obvious, and yet I can't hit on the correct syntax.  What is it please?
ms
Super User ms
Re: Referencing TableBox columns by their position within the TableBox
The MyTableBox[3] construct should work. Default table boxes in JMP platform reports can contain hidden colboxes that also counts. So MyTableBox[3]<<select selects the third colbox but it may appear to select the second if there is a hidden/empty colbox in between.
Example:
Open( "$SAMPLE_DATA/Big Class.jmp" )
<<Bivariate( Y( :weight ), X( :height ), Fit Line(), );
r = Current Report();
for(k=1, k<=5, k++,
for(i=1,i<=11,i++,
r[Table Box( 4 )][i] << select;
wait(0.1);
r[Table Box( 4 )][i] << deselect;
r[Table Box( 4 )][6+k]<<unhide
ms
Super User ms
Example:
for(k=1, k<=5, k++,
for(i=1,i<=11,i++,
wait(0.1);
I must be going mad.  I've just tried that construction myself again and it works perfectly; unfortunately I didn't keep copies of my earlier attempts so I can't revisit whatever I was doing wrong the first time around.
Many thanks, and my apologies for not persisting!
